I know making a bootable SD card is complicated by the different computer systems and software versions, but I'd like to know for Windows 7 if there is a better way then using the following command line method.
This method works fine but I'm not a fan of command line stuff since you can really do some damage if you don't know what you are doing (like me). Are there any recommended utilities to make bootable SD cards for TZT MFDs?
To make a bootable SDHC/SD memory card for Windows 7, follow the steps:
Connect the SD/SDHC card to your computer – make sure the card is empty
and you do not have any valuable data in the card.
Go to Command prompt – In order to do that, go to start menu and type
cmd and enter.
Go to diskpart – type diskpart and enter.
In the new window, type; list disk – the window should be system32/diskpart.
From the list of the disks that your computer has, look for your
SD/SDHC card. you can refer to the memory space of the disks to
identify your SD card.
Type; select diskX – the name of the disk you want to use i.e. the SD card.
Type; Clean
Type; Create Partition Primary
Type; Active
Type; Format Fs= NTFS Quick
Type; Assign
Type; Exit
