K kklix New member Apr 6, 2018 #1 I would like to know where I can get procedures to check the magnetron and heater current on Navnet3d, MFD12, xn10A/3.5 open array with a RSB118-092 gear box...
Deep Blue Acoustics Sage Staff member Apr 6, 2018 #2 kklix, Here is a diagram on the test points used for checking the Magnetron and Heater Voltage on a RSB118-092 Gearbox. Hope this helps..? Deep Blue -
K kklix New member Apr 7, 2018 #3 Thanx Blue... Are there different measurements for different range scale...if not what range scale is used for these measurements. Thanx
Deep Blue Acoustics Sage Staff member Apr 9, 2018 #4 kklix, The voltage on the magnetron doesn't change, (it should be around 7.1 vdc) so it really matter what range scale you use to check it. - Deep Blue
