Loss of bottom while underway
Tolock1
I am having an issue reading the bottom while underway. It happens once the boat hits about 20knts. What setting needs to be adjusted?
I have 2 TZT14's connected to the Dff1-uhd.
Thank you for your help.
Tom
If you are only losing bottom at speed it is most like turbulence over the transducer face.
There is no setting that can cure it. Do you have a picture you can post of the display at speed?
I do not. I will try to get one next weekend when I am on the boat again. I think you are correct, when the boat was out of the water last I thought I noticed the caulk around the transducer needed some work.
Thank you
