flowmotion
I am experiencing occasional failure of my internal GPS in the TZT2. The unit is about 9 months old. I am using the internal antenna.
Today after about an hour of running off shore the GPS started acting very strangely. It showed the boat moving faster than the drift speed and sometimes shifting direction while drifting (by 180 deg!). Then I began losing position and recovering it. A few minutes after that the position never came back. Sky view showed no satellites. I tried complete powerdowns (battery switch off) to no avail. Several hours later, when almost back at port, the GPS magically started working again.
I don't believe it is a loose wire. I suspected low voltage but running the generator was of no help.
The only cause I can think of is overheating of the unit. It flush mounted in an enclosed partition. Also in there are the DFF1-UHD and DFF3D modules. The outside temperature on that day was 92 F.
This doesn't happen on all trips. I run the same equipment every time.
Any suggestions?
Any suggestions?
