Integration of R599lm to TZT touch2
Dia72
Hi,
Is it possible to integrate the R599LM 3kw transducer to tzttouch2? If not what is the model that it can be used used with (anyone used it withfcv 1150)?
Thanks a lot
Dia72,
The best way to use a R599LM with the TZT2 is to use a DFF3.
That transducer will work with the FCV-1150.
One last question and sorry inconvenience, does the R509LM work woth tzttouch2? If yes, what is the blackbox?
Regards,
Dia
Dia72,
The sounder in the TZT2 is a 1kw 50/200Khz, basically low/high. The R-509LM has a low/medium combination. So the answer is no.
Hi Snips,
If this is the case then why would R599LM work if it is also 3kw and has Low and Medium? Is it because of the DFF3?
Dia72,
The DFF3 is power and frequency programmable so it OK to use R599LM with it.
Hi Snips,
Sorry for the confusion, but if the R599LM works with TZTtouch2 through a DFF3, why doesn't the The R-509LM works with it also through a DFF3?
Sorry for asking a lot.
Dia
The internal sounder of the TZT2 is not frequency and power programmable.
The DFF3 is, no matter what MFD it is connected to.
So this means that the R-509LM through a dff3 will work with tzttouch2, correct?
Just want to confirm in order to purchase dff3 and The R-509LM and connect to tzttouch2.
Dia72,
You are correct. The only way to connect the R-509LM to TZT2 is by using the DFF3.
Hi, i am the potential client to the below requests. i would like to ask your opinion on what is the best setup for my 32 Foot Deep V boat. I do all kinds of fishing from Tuna to very Deep Dropping unto 1000 meters. I want to go with Furuno products but i need to have all the below features please:
1- BDS
2- Accu Fish
3- Rez Boost
4- FDF
5- FFS
6- Side Vision
7- Downvision
8- 3D Vision
Let me tell you what i have and if they can be used or you advise me to use any:
1- R509LH 2-3 KW Airmar Transducer (Thru Hull)
2- R599LM 2-3 KW Airmar Transducer (In Hull)
I am OK to have 2 Screens or Units if i can get all i want and use any of the Transducers i already have or choose to use one of both.
i am looking at a full system that can give me all what i want and please feel free to let me know what i exactly should be looking at including any black boxes or accessories required.
i do not do this kind of change very often so i want you to kindly and seriously direct me if possible to install once and for all a reliable setup.
you can send me a mail on kgb@cobranet.org with your complete answer the soonest please as i need to decide and move forward.
thank you.
kgh666,
While the R-509LH and R-599LM are nice transducers neither of them have "Side scan or 3D" capabilities.
