HDMI INPUT "ENABLED" - 2nd monitor video options ?
CBNW
If we enable the "HDMI INPUT", can we still access the analog and IP streaming video sources on the 2nd display ?
The acknowledgment message says "the video will be disabled on your secondary display and vice-versa" - is this message stating "ALL video sources" are disabled on 2nd display or just the HDMI video source is disabled on 2nd display?
TZT2BB
V9.56
If you go to the menu / cameras / HDMI - and enable HDMI (default = disabled). The message immediately appears.
This is also referenced in a couple of the Camera / Monitor tech docs on the TZT2BB support page
(accessing_secondary_display_on_a_single_monitor_tzt2bb)
(1741824471600.png)
Please refer to para 11-2 in the ops manual that shows a full table on what video can be shown at the same time on an MFD.
JE,
I found the following on 10-2 of Operator guide.
To clarify - when this guide says "images from a max of 2 cameras can be displayed simultaneously".
They specifically mean "1 camera image per monitor on 2 separate monitors (simultaneously) " - correct?
I believe that means two regardless if you have one per screen (two total) or two on one monitor screen. The table still applies so for example, you see from the table that showing both analog 1 and analog 2 at the same time is NO, which means you can't even though it is just two cameras.
