Hi there. Simple question really! I am installing a GP39 on my boat and need to remove the coax plug from the antenna cable to pass through bulkheads etc....but how do you remove plug. Manual says remove with 3/8th inch open wrench and needle nose pliers but the plug appears to be a compression fitting. If so what type of plug do I need to source to replace with a removable version? Thanks for any help
