Furuno FIP-460 camera
It can but requires some configuration work. It would be setup on the same IP addresses set in the TZT, TZT2, or TZT3 for the Axis camera(s). The FIP-460 out of box is setup for easy use with the XL series. While it can be used for many of the prior systems, it would require someone to use a PC and configure the camera.
