J
juangarcia76
hello is my first message, but I've been reading them for two years when I bought my furuno-fcv 628 and first of all I wanted to thank you for everything I learned.
since I was put on note that I did not mark waypoint when I pressed the mark key, reviewing the installation I saw that I had left the cables of the Nmea 0183 white blue green yellow yellow and that is why its fault so I'm planning to fix it and connect it but I'm very lost if the equipments are compatible, I have a gps plotter advansea c56 and a furuno 628 the advansea brings output and input nmea 0183 like the furuno but I have read here in the forum that some equipment is not compatible and you do not need a converter
I upload the schematics and features of the gps aver if you can help me
I thought to connect it if they were compatible:
advansea c56 furuno 628
pin 6 nmea out 2+ RD-A+
pin 1 nmea ground - RD-B-
pin nmea in 1 + TD-A+
pin1 nmea ground - TD-B-
thank you very much for your help,
greetings
greetings
