furuno 628
RezBoost™ is a revolutionary new signal processing technology developed by FURUNO that improves resolution and target separation when using conventional narrowband transducers. Spot individual game fish surrounding bait balls, as well as fish close to the seabed. With the dual-frequency (50/200 kHZ) RezBoost™ technology, not only can you expect higher resolution and crisper visuals, but also improvements in the ACCU-FISH™ function.
With RezBoost™ the capabilities of conventional narrowband transducers can be dramatically improved. Compared to conventional signal processing techniques (FDF), a RezBoost™ sounder produces an image that is up to 8 times*1 clearer. A TruEcho CHIRP™ Fish Finder (requires a special transducer) produces an image that is up to 10 times*1 clearer when compared with FDF. However, what can be done with a conventional narrowband transducer and RezBoost™, just like the one you might have installed on your vessel, is truly impressive*2.
*1 RezBoost™ performance may vary depending on depth, range and signal frequency used.
*2 The Enhanced mode of RezBoost requires a RezBoost capable thru-hull or transom mount transducer.
