A Anonymous Guest Nov 26, 2016 #1 Hi i have a furuno 585 and require a 1kw transducer thru hull is the ss264w the one to go for or is there anything else to choose from Thanks.
S Snips Guest Nov 26, 2016 #2 Haines575, The FCV-585 uses the same transducers as the FCV-588. While you could use the SS264W, I would look that the transducer section of the FCV-588 to see additional 1kw options. Snips
A Anonymous Guest Nov 26, 2016 #3 Hi snips, Thanks for the reply. So if i was to go a ss175hw would this work on the 585?
S Snips Guest Nov 26, 2016 #4 Haines575, To assist you better, tell me a little more of what type of fishing you do and what type of vessel you have. Snips
A Anonymous Guest Nov 27, 2016 #5 Its a 6mtr fibreglass half cab Fishing is in max 100mtrs mainly for tuna and bottom fishing
S Snips Guest Nov 27, 2016 #6 Haines575, If you need to go with flush mounted transducers stay with the 264 series. Snips
