I have the MFD12 that came with the boat I purchased second hand. The finder worked fine and then one day was not working properly - the high freq does not properly work any more, and the low freq is occasionally way off, or takes some time to re-adjust, e.g. when moving from deep water (>600ft) to shallow (<100ft) I will find myself in 60ft of water. The other day I was running in about 6' of water and it told me it was over 800ft deep. It reset itself eventually, but I am trying to determine what has gone wrong.
At rest at the dock, both LF & HF read correctly.
I did upgrade the system from 2.02 to 2.07 that ended up with a reset of everything, and I wonder if the upgrade has changed the settings. I have put in place current screen shots; if anyone can advise what I might try I would be most grateful.
View attachment DFF1 BBDS Screen Shots.pdf
