FI70 Powering off
mikek
Is there a way to turn off an FI70 when there is power to the NMEA network? I have two FI70’s and on each one, if I push the power button it turns off but immediately turns back on.
If you press and hold the power button, you should get a countdown 3..2..1 and then it will shut down. If it isn't turning off, I suspect your are not holding the power button long enough.
