FI70 nmea 2000 pressure sensor
hori
Was thinking about adding a nmea 2000 press sensor for my fuel filter and was wondering if the FI70 could pick it up. The actual data output is one PGN 130314. I would buy one if my FI70 would show pressure data, anybody know?
Take a look at what PGNs your pressure sensor or CAN Bus device can output. For example, in the case of the Maratron CLMD16, the CLMD16 will transmit PGN130314, but also identical SIDs for 130312 (Temperature) and 130311 (Environmental Parameters) to indicate that the readings are linked together (i.e., the data from each PGN was taken at the same time although they are reported at slightly different times). While the FI70 might not take PGN130314 per say, it can take the other two PGN130311 & PGN130312.
Hope this helps, :sail
- Maggy
