I'm having trouble interpreting the NMEA connections.  I need to connect to a Northstar 6000i display.  The FCV587 manual identifies:
1 TD-A WHT
2 TD-B BLU
3 RD-A YEL
4 RD-B GRN
The Northstar unit identifies:
NMEA port 1 input A brown
NMEA port 1 input B blue
NMEA port 1 input ground white with blue stripe
NMEA port 1 output A violet
NMEA port 1 output B gray
NMEA port 1 output ground blue with white stripe
NMEA port 2 input A white with brown stripe
NMEA port 2 input B brown with white stripe
NMEA port 2 input ground white
NMEA port 2 output A yellow
NMEA port 2 output B orange
NMEA port 2 output ground black
RS-232 ground tan
RS-232 RX green
RS-232 TX red
External ground/foil drain white with orange shield
What connections do I need to make. Thank you and have a good day.
Rich
			1 TD-A WHT
2 TD-B BLU
3 RD-A YEL
4 RD-B GRN
RS-232 ground tan
RS-232 RX green
RS-232 TX red
Rich
