Fcv295 quit reading bottom?
I have an FCV295 connected to an Airmar cm599LH pocket mounted. I was out in deep water testing this setup for the first time. Initially it started reading the bottom great. I was in 2000 feet. I was in manual depth range where the only allowable setting is 3000 feet so I decided to try Auto Range. As soon as I put it in Auto it started searching for the bottom cycling in increments of 2000 feet all the way to 10,000 feet. It never found bottom and when I put it back to manual it still will not find or mark bottom at any depth. I tried resetting it to factory defaults and played with every setting there is. Nothing. It looks like it's seeing the transducer in the upper menu bar and I can still select frequencies. I'm stumped?
Please Help!
Please Help!
