While still working on the issue to determine if I need to replace my transducer, I thought I would post a second issue which may be related.  While fishing around a rig in 6000' of water, the picture advance slowed to a crawl in Dual mode (LF and HF displayed) even though I had the range set to 200' and 600'.  I believe the range setting determines the speed of the xdcr ping so I would have expected the display to advance quickly.  It was like watching paint dry.  I use to set my 292 which I recently replaced with the 295 in this way and it worked perfectly to mark bait and tuna around the rigs.
I adjusted the Pic Advance setting which had no significant impact on the speed and caused the display to look suspicious. I tried setting everything to auto, everything to manual, HF only, LF only and no settings seemed to make the display usuable.
Once back in less than 500' of water, I notice the performance was back to what I would consider normal on the HF. As explained in another post, the LF has not performed well in any depth yet. Any suggestions?
