Solution,
Maybe I am still missing your question.
The 295 won't show a digital depth in 2500ft if the range is set to 400ft.
The TVG settings are the one that will adjust the sounders gain in the water column. Normally the TVG Distance is set at 600ft, is means the sounder won't reach whatever the main gain setting until 600ft. If you want more gain in the 0-400ft range, lower both the TVG Level and Distance settings. Just to see what they do is next time out lower both of them to there minimum values and watch how much clutter appears.
Hope this helps.
