fcv 585 wiring
I have a red fused wire, a black fused wire and a black wire. Does the black wire with the fuse go to ground?
The black wire (Cable shield) is already grounded internally within the display unit. You only need to connect the Red (+) and Black (-) wires that have fuses attached. If you ground the black shield wire, it often results in the unit not powering on.
