Hi, just acquired a new to me VX2 setup with RDP149, ETR6/10, RSB-0071 and FAX30 weather receiver with all cables, and the FAX-5 active coupler. Only trouble so far during the inspection is that the cable has been cut on the FAX-5, presumably when removed. Is there a replacement connector I could put back on, or if I send it in to you, can the cable be replaced reasonably? New FAX-5s are $400 bucks and weather isn't that important to me. I am changing over from a Raymarine system that has not been very good...the radar was a joke and network problematic.
Attached is a photo of the FAX 5 and then a mystery black pigtail...what is that?
Thanks for your inputs!
