Checked the jumper. It is correct. Went to mast top antenna, cleaned ground, scraped paint to make sure it was going to ground on a steel vessel. Turned on the vessels SSB and tuned to the fax channels noted in the Fax menu. While some are a little noisy, on in particular was quite clear. This was 12412.5 out of Kodiak. Even when I selected that as listen channel in setup, it would not receive the signal, in auto mode it only pulls down 4298.0. The screen that contains station, standby, SS and SN blinks rhythmical once a second. On a previous vessel I had the paper Furuno fax and it received signals fine. This unit just hasn’t. Wasn’t an issue until the Coast Guard repeater stations began failing last winter. Perhaps a Furuno contact for the issue? I am a Furuno dealer for the area.
