I have a FA50 AIS. It is not transmitting. Unit was tested last week by Furuno in Camas WA. It tested fine and transmitted fine. It is running the current software version. I’ve tested the dedicated AIS antenna and its wire. SWR 1.5. After a series of NMEA 2K tests, it appears that the GPS antenna is the fault (NG using the FA50 test feature).
Which GPS antenna using an NMEA 2000 connection is compatible with the FA50 so that I can purchase a new unit?
Thanks -
Thanks -
