I came down to my boat today to check everything out before a long weekend offshore. I Fired up the electronics and received an error on my autopilot (SYSTEM HAS FAILED STARTUP TEST PLEASE CONTACT A LOCAL FURUNO REPRESENATIVE FOR REPAIR). I rebooted the unit to watch system check and see everything ok except Controler ROM NG. I assume that means the read only memory in the controler is bad. Can any body help with a fix/ solution? Does this mean the head unit is bad? Thanks in advance
