FA70 Shows up in Sensor List, but cannot access in Network Sensor Setup on TXT24X
Wild Blue
Hi, recently installed many Furuno pieces of equipment in my electronics refit. Went very well, most all plug and play.
Trying to program the FA70. I see it in the Initial Setup>Data Sensors>Sensor List>CAN Bus Sensor.
But when I go to Initial Setup> Network Sensor Setup, I do not see it. I do see the SCX-20 installed in the system.
I downloaded the AIS Setting Tool, including the USB driver. But the USB Driver won't install due to no signature. I have a laptop WIN 11, no CD-ROM to use disk sent with FA70. SO I can't connect my laptop directly to the FA70.
Any help on accessing the FA 70 would be appreciated.
Appears to be resolved. Not sure what made the FA70 visible in the Network Sensor Setup. The next day I was applying the NavNet Network Sensor Update that I downloaded from the FA70 Software page. I put the USB memory stick in one TZT24X and powered up. It loaded the Network Sensor Update. I powered the 2nd TZT24X up also. While I was looking at the unit with the USB memory stick, I also looked at the other unit under the Network Sensor Setup and noticed the FA70 was now showing. I had not applied any of the updates. But the entire system was restarted this day.
So everything looks good right now. (do have separate question on the NavNet Network Sensor Update package and will start a separate thread)
