Some of those radios use a higher baud rate of 38,400. I would recommend first verifying you have data coming in showing up on the Vx2 port monitor. If you look at the port monitor for data 2 it should show you the data coming in. If the data looks like hieroglyphics then it is most likely at a different baud rate. You should change the baud rate of data 2 to match what you have wired in. Once received and matched, your port monitor should show the NMEA 0183 sentences coming in clearly.
