Equipment & Depth Limits for Bottom Discrimination (or Hardness)?
FishHunter
What equipment combination would give maximum depth for bottom discrimination or hardness out to TimeZero (down to 1500ft)?
It looks like the FCV-1150, FCV-800, and Touch2/3/XL all provide this feature, but I'm confused about listed bottom discrimination transducers because they seems to be mostly 600w (so can't take advantage of the FCV-1150/DI-FFAMP power levels).
1. Are there any higher output transducers compatible with bottom discrimination/hardness?
2. Can CHIRP do bottom discrimination/hardness or is this a CW only function?
(edited to reflect interest in discrimination OR hardness output for TimeZero)
Bottom discrimination only works from 5 to 100 meters no matter what equipment you have.
The FCV1150 doesn't have bottom discrimination feature like the FCV800 and TZ Touch displays. The FCV1150 has a bottom hardness feature if you connect one of the Furuno specific transducers listed as CAxxxx on Furuno USA website. The FCV800 also has a bottom hardness feature.
The FCV800 and TZ Touch displays each have a list of compatible bottom discrimination transducers shown under accessories for each display model number.
Here's a link to our website: https://furunousa.com/en
Thanks! I was getting confused about that. Thanks for clarifying the 'Bottom Discrimination' has a depth limitation. I've been reading through https://furunousa.com/en all week but couldn't find an exact range :geek:
Thanks for the CAxxxx transducer reference. Is there a maximum depth for bottom hardness? Or is it just a function of the transducer power/range?
Is bottom hardness a display feature, or just a data output feature?
Lacking the feature, just set your depth range for >2x the depth and watch the 2nd echo. It's colorfulness/strength is a good indication of hardness.
I'm interested in being able to output discrimination/hardness into TimeZero so I can map it for future reference. I've edited my original post/title to reflect this.
It sounds like the FCV-1150 (with 2kw more output than the FCV-800) would get me max depth, I'm just unsure of the depth limits for the hardness function on the FCV-800 and FCV-1150. Prefer the FCV-800 for the size, wonder if combining it with an 3kw transducer (for max element size) would get me what I'm looking for.
