DRS12a radiator movement
Jsubzero
Hello I Have a Drs12a unit and its brand new. while washing the unit I discovered side to side play in the radiator bracket it self not the attenna is this normal to have play side to side ?
You will normally will feel a bit of bumpiness when you turn the unit (Gears). There is a VERY small amount of movement (almost none) when you rock the antenna (minuet bearing play). You should see that the array has sealant on its underside where the antenna meets the gearbox (or it wasn't installed correctly).
