matthewhynes
I have a DFF3D and a DRS6AX radar scanner that I typically use through 2 independent PC's with TimeZero Pro in my wheelhouse. I find the PC/TimeZero software/32" monitors provides the best results for my application and therefore I do not have an MFD in my wheelhouse. However, I have recently installed a TZ Touch3 at my aft control station for easy reference while fishing, which is adhoc. I do not want to have to have the MFD running all of the time, but I am noticing network issues when it runs, which I believe is due to a DHCP server conflict that it creates while on the network. If I set the TZ Touch3 to a slave, I believe I will lose access to the charts installed on that device. Is there a way to disable the DHCP function on the TZ Touch3 while maintaining charts on it?
