Sleipner93
Hi. I was lucky to get hold of a second hand B260 transducer. Im not sure which sounder it was used on earlier. The old cable on it was like the one on the picture i add here. So i got hold of a Furuno 10-pin connector cable, cut the transducer cable and soldered it together. Im using it with a Navnet 3d and Dff1 module. It works, but i think it should work better.
On the sounder display i will get a lot of "plankton"/disturbance both ond HF/LF even with gain almost on zero.
I wasnt able to get the total correct schematic for the soldering, is it possible that i've mixed up the HF/LF cables?
The temperature also shows incorrect value.
Are there different kinds of B260 inside the transducer? I thought they were all the same with different connectors in the end ? Its a pity if this transducer wont fit to the Furuno system..
