madmike":3bvva57y said:Is it possible to disable the TZT3's DHCP server? Or to change it's IP address?
I already have a router on the boat that has a DHCP server. It's on the same subnet that the TZT3 defines with its hard-wired IP address. I use the router to assign fixed IP addresses to a YachtDevices NMEA gateway and the Victron Cerbo GX. It all works great, except if the TZT powers up before the router: it will assign the wrong addresses.
madmike":3qtozi0w said:Johnny, does "the supported design" mean separate Ethernet networks for (1) the main boat network (internet connection, tablets, laptop, Victron CerboGX, etc), and (2) Furuno chartplotter and radar? And the chartplotter connects by wifi to the boat network so it can reach the internet?
The only reason I started getting into the IP address of the chartplotter was to get it talking to the CerboGX for battery & solar monitoring.
Thanks.
Mike
Does this mean every time you turn it on? Or the very first time? I cant even remember which one powered up first. Ive turned off dhcp on my router.The first TZT3 that powers on is the data talker for DHCP and NMEA 2000. The system automatically takes care of that. Units default to that setting On and shouldn't be changed because it is in place for approved third party device connections like SeaKeeper.
