Tpalmerjr3
Having a Camas 28 HB built and working on the electronics package. I've run Furuno on my last 2 boats, the latest the TZTouch2 12" and want to do the same with this one but the TZTouch3 12". The problem is I would really like to run the DFF3D this time and looking for some assistance with transducer selection. I will have a B60 thru hull 50/200 wired direct to the MFD as well and is mounted just forward of the first step. The boat has a Michael Peter's SVVT (stepped Vee Ventilated Tunnel) hull which throws a rather large wrench in the equation. The main questions:
1. The Transom Mount very clearly says not for stepped hulls, presumably for aeration problems. If used, would I at least be able to get to a modest trolling speed, 6-8 mph, and keep picture.
2. Would a thru hull (preferred) be too much impact on performance/handling if I could even find a suitable location. Also, boat will be trailer store.
3. Any other ideas would be appreciated.
Hull design below
Hull design below
