DFF3 with TM265LM
Aggeloseco
Goodmorning, I am aware that DFF3 is the same as FCV295, and I am aware of the blocked frequencies of the system. I have read a lot of information about the tests being done with FCV295 and TM 265LH, as I understand the sweet spot of L would be 42Khz, but I think no Test has be done for M frequency. Do you have any idea on how should I setup the Medium setting?
I haven't heard of the medium having a particular sweet spot. I think as long as you are in the rated range of the transducer medium sweep freq, it will be about the same across the entire medium band range. If there is a sweet spot, C-Bass or DeepBlueSea should chime in.
Page S1 of the DFF3 manual shows the interconnection diagram wire for wire. You only need to know the colors of the HF and LF from the Airmar transducers but they are marked on the cable label. If you get stuck, I recommend calling into support of your Furuno distributor. If that is FUSA, our support numbers are 410-479-4420 and 360-834-9300. You will also find many wiring examples already posted on this forum.
