Hi, I need your support to configure my new sounder Furuno TZT2 with airmar’s transducer. ı I have used M260 and already installed in my boat, which I have used with my former Lowrance HDS8. My questions are:
1) Is M260 suitable to use with TZT2?
2) Or if I want to update my transducer to chirp transducer, what should be the combination? (B265LH is not an option as the boat has no flat surface and if I use high performance fairing, then the balance of the boat will be not good as she is very speedy)
Is it possible using B175L and B175H (or SS175L and SS175H) together with Furuno DFF1 Blackbox? And how would be the performance then?
Thank you in advance
Hakan
Hakan
