DFF1-UHD to MFDBB
Hi, I currently has a DFF1 attached to my BB. I noticed there is a CHIRP version of the DFF1. Wondering if the DFF1-UHD is compatible with the MFDBB?
As with the DDF1-UHD, what advantage it has over a newer MFD like the GP-1971F that comes with the CHIRP build-in.
thanks for your time.
little-nellie,
Yes, the DFF1-UHD is the CHIRP Black Box Fish Finder Module that compatible for use with NAVNET3D, NAVNET TZtouch, and NAVNET TZtouch2.
And if you pair the DFF1-UHD with a B265LH or CM265LHG transducer, it will provide you with ACCU-FISH and Bottom Discrimination capability.
- Deep Blue ;)
little-nellie,
The current Transom Mount CHIRP Transducer that will work for the DFF1-UHD is the: TM275LHW.
This transducer has a Temp Sensor, and CHIRPS the Low Frequency at 42-65 kHz, and High Frequency at: 150-250 kHz
- Deep Blue ;)
