Quitsa
Can the DFF1-UHD be set to operate at customized fixed frequencies? Some of the other CHIRP sounders allow this function so you can either operate in CHIRP across a band or pick a specific frequency within the band, e.g. in low you can operate at a fixed 38Hz or a fixed 65Hz or anywhere in between. I know from using the DFF3 that it is possible to select a custom frequency with that unit if the transducer is a "broadband" that supports it.
