flowmotion
I am using both of the above modules. They will interface with the TZtouch2 via a commercial Ethernet bridge. The TZtouch2 installation checklist mentions dip switch settings for the DFF1 and DFF3 modules only. It does not give information for the DFF1-UHD or DFF-3D.
The DFF1-UHD operators manual describes how to set the unit to static IP or DHCP using dip switch 2. It does not say which one to use for networking with the TZtouch2. If switch 1 is to be set on, what is the correct position of switch 2.
The DFF-3D operators manual describes how to set the unit to static IP or automatically assigned IP using dip switch 2. It does not say which configuration to use for networking with the TZtouch2. The manual also has a logically inconsistent description for switch #2. It says a) see table below for IP address, the b) currently this function has no use. Can you clarify these statements?
In summary, I would like to know the settings for dip switch 2 for the DFF1-UHD and DFF-3D modules when networked with the TZtouch2 MFD.
Thank you
Thank you
