Depth data loss On maxsea tz plot
Status
Not open for further replies.
Hi,
I've just reset my fcv 1150 sounder to factory settings and now I have lost the depth data to maxsea tz plot. I've checked all the Ethernet connections, the NMEA output on the fvc1150 is on in/out. Tried on the maxsea connection wizard it won't pick up the depth data on the NMEA input. The depth is showing on the sounder. Any ideas would be great?
If you're using the FCV1150's NMEA0183 connection to the TZ Plot program, then ensure "NMEA Output" = "ON" and "TLL Output" is "TLL" under Menu-System-NMEA. Then, re-run the connection wizard on MaxSea. If it still doesn't work, ensure that the RS422-RS232 converter is still working properly on your computer in Windows device manager.
The navnet option was turned off when I reset the sounder.
Status
