DEEP DROP FISHING
michel611
HELLO
I HAVE THE NN3D MFD12 AND I WORK WITH THE BBDS1 AS FISH FINDER AND ITS GOOD FOR 100 METER AFTER THIS DEEP I NEED TO SLOW DOWN TO MIN
I WANT TO WORK IN DEEP DROP FISHING SOMETHING LIKE 150-450 METER WITH 3 KW TRANDUCER IN 38 KHZ FOR BOTTOM GROPPER FISHING THE CA38BL-15HR
1. DID THE FURUNO NAVNET SOUNDER ETR-30N WILL DO THE WORK FOR ME LIKE THE DFF3 WITH FULL CONTEROL FROM THE NN3D,OR I HAVE TO BUY THE DFF3 ?
2.DID THE ETR-30N WILL WORK WITH THE NN3D AFTER HUB 101(8 PIN TO RJ45)
3.DID THE ETR-30 WILL WORK WITH THIS TRANDUCER ITS NOT WRITE IN THE BROCHRE
4.DID THE ETR-30N OR THE DFF3 WILL WORK ONLY WITH ONE TRANDUCER LOW FREQ?
5.TO WAIT FOR THE DFF1-UHD WITH CHIRP AND AIRMAR B265LH ? IT WILL DO THE WORK FOR WHAT I NEED ?
The ETR30N (older analog network 1/2/3kw sounder) will work on the NN3D but not the TZtouch. You would need the proper network cable from the MJ6 (6 pin) connection to a normal RJ45.
michel611
hi johnny
for fishing i want to coneccet the mfd12 to hub101 go to etr-30n than go to bt-5 to CA50F-70
it will work?
i want it becuse it have 6 degree Beam Angle for deep 500-700 meter
Yes, the BBFF3 will support the BT-5 and the CA50-70.
It would be best to ask Snips about how it would work (fishing wise).
