Constructing a route
dalee62
I am wondering if it is possible to build a route by recording all the lats and longs off a paper chart and then entering them in a new route in the order that they would occur on the water. I cannot find this topic in the manual. If it's there could please point me in the right direction. I have entered lats and longs in the "GO TO BY POSITION" box but can't figure out how to enter a series of lats and longs to make a route. Thanks.
Dave
Melville
Dave-
In order to create a route from the waypoints you entered you will need to connect them from the chart screen using the route function. Your route points will be the same as your waypoints. This routing function was designed so as to check the safety of the desired route while it is being created.
This is the only way available to create a route.
