SailorLinda
I have a Navnet 1834C chart plotter which is an awesome unit, but now I have a problem with the GPS. It is a long story but basically the Furuno GPS is gone and I have had to replace it with a Garmin GPS - the only one available at this time and location. I have read many forums on line and it seems like I should be able to splice the Garmin wires to the Furuno wires (which are still intact and are "plugged" into my chart plotter).
Ignoring the red and black power and ground wires the Garmin manual shows colours of the wiring as:
white/orange Rx/B(In-)
white Rx/A (In+)
Gray Tx/A (Out+)
white/red Tx/B (Out-)
From the Furuno manual
The colours of the Furuno wiring are
White TDA
Blue TDB
Yellow RDA
Green RDB
And the manual states that RDA and RDB (yellow and green wires) are the input for the Radar/plotter.
I am connecting the Garmin Gray and white/red wires to the Furuno yellow and green wires.
The 12 volt power is on (tested with a volt meter).
This splicing I have done is not working for me.
When I check the sentences for Port 1 on the port monitor they are garbage, no info at all, just random symbols and letters. And when I check the signal for the GPS it shows me no satellites are found.
I need help. Without a GPS input my Furuno chartplotter is non-functional. Any suggestions are welcome and I will try them. I cannot purchase a Furuno GPS from my cruising location so that is not an option.
Sailor Linda
white Rx/A (In+)
Gray Tx/A (Out+)
White TDA
Blue TDB
Yellow RDA
Green RDB
Sailor Linda
