I previously had a Garmin system installed, including a B175H transducer. I expected that the B175H would also be compatible with the new TZT3 16" unit I installed. I cut off the Garmin connector, cut the Furuno 12-10 pin adapter cable, spliced the wires and connected the transducer to the Furuno pigtail. I spliced each wire, color for color. There are the same number of wires in each cable, and the colors are the same, so I matched blue to blue, white to white, etc., and the splices are neat and solid. I also understand that the B175 units are now offered in 'mix & match' fashion where the same transducer can be used on 'any' brand system simply by swapping out the terminating connector pigtail, reassuring my belief that this 'should' work.
The boat is still out of the water, but a few things make me think my installation is not Kosher. On the up side, the transducer does seem to 'work'. When I power it on (only for about 15 seconds at any time to prevent damage), I can see a return that makes sense given the situation of being out of the water. On the down side, I expected the TZT3 to recognize the transducer via XID--this didn't happen, I had to select the transducer model in the setup menu. More bad news, I am not seeing any sea surface temperature reading on the TZT3. I have confirmed using a multimeter that the thermistor in the B175H is working, with a resistance right around 10kohm. I have confirmed that the SST source is set to the TZT3 unit the B175H is connected to. The XID feature worked fine with the Garmin system, although that is not easy to check with a multimeter like the thermistor is (or is it?).
What am I doing wrong?
