On the first start up this season, the COG is missing from the MFD12 data. It worked fine last season, but is not available after sitting over the winter. I use Maretron GPS on the NMEA2000 network. COG is available on the Maretron display, as well as on the Furuno dedicated instrument displays. Troubleshooting on the Maretron system shows that COG is being output by the GPS and is on the network. So I must have a setting wrong on the MFD12.
I've worked through the menus and tried redoing setup, but haven't been able to find the problem.
Over the winter, I did have the GPS firmware updated. But since COG is available on the network and visible on other displays, that doesn't seem a likely cause.
Any ideas?
Any ideas?
