cmor vs cmap
Jsubzero
I have attached two side by side shots from cmap and cmor the exact same locations from the chart for each. Can you tell me when Furuno will have the cmap chart available as it shows more detail than the cmor.
more screen shots to compare
That might be something to ask C-map. They might or might not tell you their future plans. For relief charts right now only C-map and TZT3 PBG are options. Depending on the area there might be bathy line charts available for purchase. I alway recommend contacting Tech Support with the Lat/Lon and see what examples they might suggest. MapMedia is working through the available database of CMOR offerings, so if CMOR has that area now, it should be long before MapMedia offers it.
Thank you.
I'm sure we will all be interested for c-map to produce these for tzt3. unless cmor comes up to date.
I'm also very interested in being able to run these on my tzt3. I think cmap calls it Reveal.
Being able to read the Navionics Platinum+ would work also. CMOR just doesn't have the coverage or at least doesn't cover us in the PNW.
