CMOR on XL
Saltybrad
Has anyone loaded the CMOR on the XL's yet? I just purchased the code, the unit said it is valid but no additional maps display on the overlay screen.
You would need to download the CMOR chart to a PC, unzip the file and then transfer the chart to the Micro SD card that is in the back of the XL.
I unzipped the MM3D files and saved them on the micro SD. When I initially opened the card, there were 3 folders on the card. The MM3D folder, the TZ folder, and another one. I saved the MM3D files without placing it in one of the folders. When I inserted the card nothing happened. I went to the files tab in settings and tried to import but nothing was there? Do I need to save the unzipped files in a special folder?
The files need to be unzipped. Shouldn't need to put them in any particular folder but you do need to enter the unlock licence code into the machine and zoom down into the area at around 5nm with the CMOR overlay layer turned ON from the swipe up at the bottom of the plotter page.
