Chirp and non-chirp at same time
Fiddy1
Hi,
Just wondering if I can run the following at the same time
FCV1150/CM599LH (non chirp)
Garmin GSD26/CM265LH (chirp)
The transducers are planned to be installed next to each other in a 10m aluminium in a custom fairing block.
Help appreciated.
Cheers Pete
Fiddy1,
Can you run them at the same time, yes.
Will you see interference, yes.
Snips,
Thanks for the reply.
Will it have interference enough to not use them at the same time or it can be cancelled out via settings.
Fiddy1,
The FCV-1150 has enough IR control to handle the GSD-26, I can't say how the GSD-26 will tolerate the 1150 however.
