M Moonzy1 Furuno Super Fan Jan 9, 2020 #1 Can you change output power from the MFD? Say you are running an R-509LHW Ducer and you want to use the LF side at 2kw vs 3kw to cut down on noise in more shallow water. Can this be done?
S Snips Guest Jan 9, 2020 #2 Moonzy1, The R-509LHW is 3kw on the LF side (Tap C) and 1kw on the HF (Tap A). Snips
M Moonzy1 Furuno Super Fan Jan 10, 2020 #3 so you cannot adjust power settings from the mfd? has to be changed inside the DFF3 itself?
S Snips Guest Jan 10, 2020 #4 Moonzy1, The DFF3 does have a power control, but it affects both frequencies. Snips
