Dan.Fuller
HI Snips,
I have a question regarding the CH250 searchlight SONAR, well maybe a couple questions.
1) While looking at the installation on a friends boat, I noted the hull unit was C181-1, which as far as I can tell is for the CH270? I then went and confirmed that the head unit was a CH250-2? However, it appears that the hull unit should have been a CH254/255? am I missing something? For our application I like the idea of a smaller seachest while having the great output of the CH250 (at 150kHz).
2) The reason we were evaluating the unit is we are contemplating installation of either a 250 or a 270 in our relatively small vessel (28 Bertram) and there are two areas of concern. A) height requirement of the installation, which appears to be about 33" minimum? and Location, as in how for forward can one be mounted? In our case, the deepest part of the hull is about 25% aft of the bow waterline and would appear ideal, but it's also on the planing surface of the hull, is that a problem?
I greatly appreciate any insights you can provide.
Thank you for this consideration!
-Dan
-Dan
