G
gordwedman
Thanks Greg, once again. I am learning a lot and I'm sure others are as well.
I have a Raymarine ST7000+, 400G computer and below decks Type 2 hydraulic drive unit. All pretty expensive to duplicate in a new system so that option is out. I suppose I might be able to just replace the 400G computer with one that had an N2K input but that is probably going to be 1 or 2K$ so also not really worth doing just to simplify the connections. Of course I did not recall that the MFD12 could asign different data streams to the Data 2 and 3 NMEA outputs so thanks for that so I see that using the PG700 would not really be an issue. I don't know if it is really worth buying to just simplify the wiring though. It might actually be harder to run a wire from the MFD data terminal strip in my engine room to my 400G than to run a NMEA0183 connection from the PG500R as the PG500R was going to be mounted closer to the 400G. I was going to power the PG500R from the same terminal strip connection that powers the MFD. With the circuit breaker ON the PG500R would be powered but I could have the MFD switched off. Since I am going to buy a N2K compatible AIS class B transponder/display I am thinking I will most likely have the MFD switched on so that I can see the AIS output so I am going to have to deal with power useage somehow. Maybe I will only use the dedicated AIS display. Could have the MFD in sleep mode most of the time. I recently crewed on a 13 day offshore passage and I was a bit surprised at how much power we used.
My orginal thought in all of this was to just add the Smart DTS transducer so that I could view depth on the MFD. After the passage I mention above I came to conclude that an analog/digital wind display was a handy thing to have, especially at night, so I started looking at the masthead transducer. When I discovered that you needed the display to convert the analog signal to a digital one that the MFD could display it seemed like a small step to add a dedicated display for DTS. Pricing all these bits separately turned out to be more expensive that buying a packaged system from Defender. Simpler to buy everything from one vendor as well. So I am going to have dedicated displays for wind and DTS. This should make calibration easy?
Now I just need to rip out all my old Standard Horizon instruments (except the depth sounder) and install the Furuno stuff. Not looking forward to working at the top of my mast :think
cheers
Gordon
cheers
Gordon
