Axis 3206 camera
Winesk
Camera works but only in black and white. When I first installed it it was in color and I haven’t made any changes to the camera since. Any suggestions?
I would connect up a PC to it and see if a BW (Black White) setting got set by mistake. If still not working; I recommend checking with Axis support why it stopped streaming color.
Trying to connect to Axis with a PC is a nightmare. When I initially installed this camera a couple of years ago it came up in colour on my NNTZ3 and worked properly for most of the season. Next season, black and white. I am pretty sure I upgraded the furuno software that spring. I recently installed the latest furuno software and the camera came up in color. Next time I started the TZ3 it was back to B&W, I have never touched the camera setting since it was installed so it seems to me the issue must be at the furuno end.
While I have you, I have a autopilot question. When I navigate to a WP it holds a perfectly straight course but when I use the Auto function it gradually falls off to port 5 or 6 degrees before correcting. Always to port the same. Is there some way to increase the sensitivety when in Auto? I am not on the boat but recall a setting in Auto that would keep a straighter course but work the pilot more. I'm pretty sure I used that setting and it doesn't seem to wander in NAV function.
There is no Furuno cases of what you describe. It sounds like your camera has an issue and maybe if left online during the update is being toggled.
When an autopilot moves off course in AUTO it is related to HEADING or Hydraulics. What is your source of heading? (Nav of the plotter will force corrections as cross track gets exceeded but still normally either will correct a lot or "S".)
