OliverFdeV
I am looking into the 711c autopilot and would like to know whether it has speed control and dynamic braking.
I found the following on the jefa.com website:
Speed control: Some autopilots control the autopilot drive unit with an on-off signal. This can result in a bumpy autopilot steering and high peak forces in the system as all movements are abrupt (no soft start and soft stop).
More modern autopilots are able to control the speed of the autopilot drive unit from 0 to 100% without any steps via so called pulse width modulation. Autopilots without speed control often start "hunting" at low boat speeds. Hunting is an oscillating movement around the mid position where the steering wheel continuously swings around the mid position.
Dynamic braking:
...due to the inertia of the wheel and the fact that there is no damping, the rudder overshoots the targeted end position and the autopilot starts to correct this and reverses the power and this goes on and on and on. This is called “hunting of the autopilot” an oscillation around the amidships position. This causes high stresses in the construction, could cause damage to the steering and rudder system, but above all will empty your batteries very quickly! Modern autopilots have a feature called dynamic braking to prevent this.
This holding power is the second advantage of a dynamic braking feature. While sailing on autopilot, the rudder needs a constant cut angle to the water flow to keep the ship on course. This requires a constant force of the autopilot drive driving the rudder. On systems without dynamic braking, the autopilot commands the drive unit to a certain rudder angle and takes the power off. But within seconds, the drive unit is pushed back by the rudder forces to the neutral position. The autopilot will have to drive the rudder to the required rudder angle again and when it is reached, the rudder slowly turns back neutral again. This not only gives a non constant course, but also uses a lot of power, causes high wear in the drive unit and heats up the drive unit to immense temperatures.
With dynamic braking, the autopilot can "grab and hold" the rudder fixed when it is a certain position and hold it without any movement and without using any energy. As shown in these points, speed control and dynamic braking are very important and make or brake an autopilot system.
So here are the questions:
- does the navpilot 711c have speed control?
- does it have a damping feature so it prevents overshooting and hunting?
- can this autopilot grab and hold without power?
Thanks for a reply.
Dynamic braking:
Thanks for a reply.
